ok pic dump..
i'll start off with my power window conversion.. not completely finished i still need to sheet it and make a new door trim.
remove all that
make up a frame and stitch it in.
massive speaker... heavy but is rated at 200wrms..
next is spare wheel well...
cut this
trace it onto this
and i jst use about 30 stainless rivets plenty strong will be bracing it through the top support a false floor
to hide ALL wiring.
and old stereo... downsizing quite abit and making much much neater..
now onto my console.. i've mounted guage pipe in it angled up and pointing towards the driver.
also plated a bottom poscket out to allow for 4 power window switches..
also had a mate airbrush it before i painted it well cleared it..
then after sanding etcetc..
then clear.
then after this i decided to give airbrushing a go myself and this is my first attempt hasn't been cleared though..
ok so here is the start of the boot anyone can do this kinda crap took me only 2hrs to get this far.
welded in some braces to give some clearance for wiring and also will be adding in some bits to attach the floor to it to give the floor the strength back
after cutting the wheel well out.
obviously this is extreme for my case but for a stock boot jst use some mdf to space it up a bit.
then make templates out of cardboard trace and cut... i wanted to do this in 2 pieces but i had no way of getting a sheet big enough home. so 3 pieces..
on its fixed + underlay+ carpet you'll never know..
the make more templates etc.
i will be doing more on this during the week and i'll keep the pics coming.. once done it'll look pretty good.
cheers mate... i plan on doing quite alot more like that,... steering shroud pillar plastics and i also plan to install some panels painted like that into my new door trims.
decided to get right int airbrushing.. i have a decent quality gun on the way and i have some spare sheet for panels.. i have a compressor jst need
to go to the hobby shop and buy some colours..
been spending quite a lot of time on the net watching videos to get techniques really excited to do it.
