well i picked the head up and it tested ok but they didn't face it.. the head is warped... so he gave me the option...
the machinist reckons that with new headbolts and a graphite gasket it'll cplamp down just fine but no gaurantee...
but if i get him to straighten it it'll be a full reco and cost 500 ish bucks...
so i'm going to bolt it down and fingers crossed she'll be ok if not i've only lost a head gasket. if it work sweet as and i can start searching for my new motor.. 5e.
if its warped can't they machine it straight or will they take too much off witch will result in 13:1 compression?
so the theory is bolt it down after cleaning it up and essentially bolting it down should flatten it out. and pull the top of the head where the cams
are straight as well. its only bent 5 thou so not heaps the ghraphite gasket he thinks is quite forgiving and the new headbolts will help out as well as they are a torque to yeild bolt apparently.. so they'll settly in how they want to. basically i'll give a go if it works then yay.. but i'm now on the lookout for another head in good nick to get cleaned up as a back up.
well all back together and still the same problem...
the water is boiling in the head but not in the block... seems like a blockage but its been all flushed...
thermostat was suggested but its brand new... i'm gonna gut my old one and put that in see if it fixes the boiling...
what i really need is to see another 4e so i can have a look at how ALL the water lines go. and compare to mine.. perhaps i have something plumbed wrong.
Welder is how they can be straightened, but didnt read properly, 5 thou not worth trying.
Did you compare head gaskets? I mean sit down and spend 10 mins comparing every little hole from old to new?
I have had a few first hand experiences where mates have had this problem, one diffent hole in hg could cause lots of drama.
i would be VERY cautious about putting a head back on that wasn't straight.
even if it is 5thou or whatever, its still not straight....
5thou = 0.127mm, thats quite significant i would have thought?
the $500 sounds about right, they would be re machining everything in the head, cam bearings, valve guides prolly too....
i did my mates head on his 98' 323 astina (huge over heat), to straighten the head, and buy a gasket set...not much change from 1100 bucks. almost replacement engine time.
yeah oh well.. its back together and its now running properly well sorta... its not overheating anymore
but there is a distinct power loss at approx 4000rpm really annoying.. i'm sure i'll figre it out.
