Love the answers you've got so far :)
The 5K head does not have a blast chamber in the bottom, the blast chamber is in the top of the pistons. The 4K head has the blast chamber in the head, pistons are flat on the top :P
I'm sure there are other differences, but this is the biggest. You can pick a 5K head because it has a rib below one of the spark plugs.
Pretty sure I've read that a 4K head on a 5K LOWERS compression, which is what some people have done when boosting a K engine.
If I remember correctly, 3/4/5k port sizes are the same. A 5k has hydraulic lifters too, whereas all other K-series engines have solid lifters!
NO! 5k head onto a 4k or 3K especially would bring the compression up to something crazy.
5K head > 3K High to VERY HIGH comp
5k head > 4K Even Higher comp
5k Head > 4K-U Stock Comression
3K head > 5k Low comp
4k head > 5K Lower comp
4K-U head > 5K Stock Compression
thanks for the info mate
yes, there`s 2 different 4k heads and 2 different 5k heads
Twin squish 4k head (as in 4k-u amongst others) are the same as most 5k heads. These have slightly larger ports than the regular "flat top piston" 4K heads, way smaler combustion chambers, and use shorter pushrods
