Thinking about trading my sedan for a wagon only thing is I'm iffy about what rear sus the wagons are able to run because there leaf right.
Just need some advice anything would be great thanks
Leaf springs certainly present more challenge for setting a car up for the circuit.
There is no easy adjustability, and if you want to do it properly, each time you want to make it softer or stiffer, you really should be talking about new leaf packs/reset leaves.
Of course there are ways around this - reversing them, adding or removing a leaf, etc etc etc.
Not to say it can't be done - plenty of old Corolla's (KE20's and KE35's) running leaf spring rear ends and doing very well on the track.
^^He's said enough about leaves, so now you just need to do some googling to find out what you want to do.
As for shocks, anything adjustable from an AE86 will fit. IE TRD 8 way adjustables like what I have. :y:
And then the rear hanger can also be adjusted in height - toe in/out in a corner and if you want to get into the whole thing of cutting/shutting/welding the front pick-up point of the leaves for either higher or lower mounts also changes the suspension characteristics, which also brings about another thing if both the front and rear mounts are moved be the same amount.
