Well no, it's not *only* affected by changing displacement, but more displacement helps to make more torque. So given all else equal, a 5K will have more torque than a 3K.
Okay, can you stop asking the same questions about how to make your K engine go fast now? Read the article Jamie wrote just for you, it tells you EVERYTHING you need to know.
  Quote
?????then what should i ask???this is an engine techincal forums isnt it???or fashion forums???
Exactly what Jamie said. We are a technical forum, but if you keep asking the same question over and over again we get a little bit iffy... Like I said before, Jamie has written you a step by step guide to how to make your K engine go fast, follow it and you will be alright. If there's something you think is missing, it's probably not worth knowing. Just follow exactly what Jamie has written and you'll be fine.
