KPROLN Posted October 25, 2009 Report Posted October 25, 2009 (edited) I have a problem with my 4age ke70 it keeps snappin the water pump thats the 2nd pump ive been frew I'm running a clutch fan would anyone have an idea what may be the problem. Edited October 25, 2009 by KPROLN Quote
parrot Posted October 25, 2009 Report Posted October 25, 2009 No idea what you are running or how it is breaking, but the front wheel drive pump is different to a RWD one. FWD isn't designed to have a fan bolted to it, plus the nose of the FWD pump is from memory longer. So, depending on what combination of pumps and pulleys you are running in rear drive configuration, possibly the belt deflection is loading the pump excessively? Does everything line up, or is the belt running at an angle? Quote
LittleRedSpirit Posted November 4, 2009 Report Posted November 4, 2009 No idea what you are running or how it is breaking, but the front wheel drive pump is different to a RWD one. FWD isn't designed to have a fan bolted to it, plus the nose of the FWD pump is from memory longer. So, depending on what combination of pumps and pulleys you are running in rear drive configuration, possibly the belt deflection is loading the pump excessively? Does everything line up, or is the belt running at an angle? What he said except the fwd pump is flusher than a rwd one, and I believe the belt runs in the same location. The rwd pump is longer to get the blades of the clutch fan closer to the radiator core. Quote
parrot Posted November 4, 2009 Report Posted November 4, 2009 Actually rediscovered this the other day http://www.rollaclub.com/board/index.php?showtopic=19896 May be helpful. Quote
mungi mods Posted November 4, 2009 Report Posted November 4, 2009 twin thermos no clutch fan... also if fwd pump the engine deflection under accelleration, decelleration may be putting stress on the pump depending how you re-routed the lower hose back to the radiator... Quote
