timlewis82 Posted October 23, 2009 Report Posted October 23, 2009 (edited) Hi i just bought a new cluster of ebay, and finally got around to installing it. I have a 78 ke55 se, the gauges are a lil different to my original. My main drama is the speedo connection that plugs into the the speedo cable isnt the same as my original..... The original is longer and the newie is shorter and wont plug in or push the pin fully in. Whatr can i do? Also, the new speedo goes to 160km/h when my original goes to 180k...... My fuel and temp gauges don't seem to be working on the original and the speedo gets stuck on 4o at idle there fore I'm going 25-30 k under speed when driving. HELP PEOPLES! Edited October 24, 2009 by timlewis82 Quote
jono1986 Posted December 15, 2009 Report Posted December 15, 2009 (edited) don't know if you have an answer yet, but when i did the conversion on my 35 i cut the original cable out (like an idiot) and got another one from UPI. The connections were different like what your describing, bought the right cable off ebay... http://cgi.ebay.com.au/TOYOTA-COROLLA-KE30...=item48389e9b62 you can see on the pic if its the right plug Edited December 15, 2009 by jono1986 Quote
