ae95- wagon kid Posted October 18, 2009 Report Posted October 18, 2009 hey would i be able to have 7afe cams re-profiled to be used as performance cams for a 4afe and would a 7afe ecu and injectors be able to be used in a 4afe if so where can i get these parts and how much are there any more torque creating mods for a 4afe i might be doing a swap later on but i wouldn't mind working a 4afe (easy to learn and work with) cheers Quote
beerhead Posted October 19, 2009 Report Posted October 19, 2009 If the 7AFE cams have a bigger base circle on the lobes I'd say you may be able to get a regrind done, the more difference in height, the more lift and duration you should be able to get. As for the ECU I'd think that the 7AFE would have a lower rev limit and retarded timing advance over the 4AFE, probably a downgrade more than anything. I'd be trying a 100kw 4AGE ecu over the 7AFE. You'd just have to double check the injector wiring matches between the 2 motors, they'll either be sequential or in banks or 2 injectors. Quote
Hiro Protagonist Posted October 19, 2009 Report Posted October 19, 2009 beerhead said: If the 7AFE cams have a bigger base circle on the lobes I'd say you may be able to get a regrind done, the more difference in height, the more lift and duration you should be able to get. As for the ECU I'd think that the 7AFE would have a lower rev limit and retarded timing advance over the 4AFE, probably a downgrade more than anything. I'd be trying a 100kw 4AGE ecu over the 7AFE. You'd just have to double check the injector wiring matches between the 2 motors, they'll either be sequential or in banks or 2 injectors. 4AFE and 7AFE have identical rev-limits. And hate to spoil everyone's parade, but the Toyota EPG lists identical part numbers for 4AFE and 7AFE cams. So no difference whatsoever by swapping them (pretty much the whole head is identical, it's the extra stroke which gives the power increase, along with ECU mapping. Quote
ae95- wagon kid Posted October 19, 2009 Author Report Posted October 19, 2009 ok what can i use to make more torque cams porting etc i want to strengthen the engine then possibly do a turbo setup i don't want to swap but can i put a 4age head on a 4afe block and if i can what would it take money resources wise cheers :) Quote
Hiro Protagonist Posted October 19, 2009 Report Posted October 19, 2009 ae95- wagon kid said: ok what can i use to make more torque cams porting etc i want to strengthen the engine then possibly do a turbo setup i don't want to swap but can i put a 4age head on a 4afe block and if i can what would it take money resources wise cheers :) The amount of effort to do a GE head swap on a 4AFE isn't worth it - either just swap in the whole 4AGE, or do a 7AGE (or just chuck a 7AFE in anyway) Quote
ae95- wagon kid Posted October 19, 2009 Author Report Posted October 19, 2009 Hiro Protagonist said: The amount of effort to do a GE head swap on a 4AFE isn't worth it - either just swap in the whole 4AGE, or do a 7AGE (or just chuck a 7AFE in anyway) i don't really want to do a swap i have a mechanic that can do a heap of stuff to the motor i just need ideas i want alot of torque and don't want to turbo i might put a 4age in but i have n o experience with toyota engine swaps is there anybody in adelaide that can do them cheaply and can i get reasonable torque from them cheers again this is really helping mate Quote
towe001 Posted October 19, 2009 Report Posted October 19, 2009 Hiro Protagonist said: The amount of effort to do a GE head swap on a 4AFE isn't worth it - either just swap in the whole 4AGE, or do a 7AGE (or just chuck a 7AFE in anyway) Yeah true very true to be able to do the head swap you'll more or less need the complete 4a-g motor - manifolds, water pump, blah blah blah are all different. About the easiest way to get more torque is to go up in capacity in the length of the stroke, hence 7a-f Quote
ae95- wagon kid Posted October 20, 2009 Author Report Posted October 20, 2009 towe001 said: Yeah true very true to be able to do the head swap you'll more or less need the complete 4a-g motor - manifolds, water pump, blah blah blah are all different.About the easiest way to get more torque is to go up in capacity in the length of the stroke, hence 7a-f i don't want to swap i want to do some head mods on the engine i have now my friends mechanic can do alot cheaply with toyota engines is there anything in particular that i can buy or come from other engines like 4age i am going to do bigger injectors what ecu should i use and what else should i do cheers :) Quote
