driftkid23 Posted October 14, 2009 Report Posted October 14, 2009 (edited) hye guys I'm doin a 4kc turbo. ive read through everything i can find and looked at all the pics over and over. but i just can't see the oil and water lines setup very well. if anyone has some really good pics that will help with this can you please post them up. Edited October 14, 2009 by driftkid23 Quote
kiahn Posted October 14, 2009 Report Posted October 14, 2009 (edited) with the oil i believe you need to run a pressurized line through a cooler and into the turbo then directly into the sump using something like the 4age oil cooler setup would probably be ideal if it screws on correctly with the water id imagine that you would run lines off the existing water system, could probably use the throttle body ones that already exist correct me if I'm wrong but thats the best i can see from all of the pictures Edited October 14, 2009 by kiahn Quote
driftkid23 Posted October 14, 2009 Author Report Posted October 14, 2009 with the oil i believe you need to run a pressurized line through a cooler and into the turbo then directly into the sumpusing something like the 4age oil cooler setup would probably be ideal if it screws on correctly with the water id imagine that you would run lines off the existing water system, could probably use the throttle body ones that already exist correct me if I'm wrong but thats the best i can see from all of the pictures cheers ill keep sussing it out. :jamie: Quote
Taz_Rx Posted October 14, 2009 Report Posted October 14, 2009 with the oil i believe you need to run a pressurized line through a cooler and into the turbo then directly into the sump.... ...correct me if I'm wrong.... You're wrong!! :jamie: No need for a cooler. You'd loose your oil pressure if you did. T piece the feed from the oil pressure switch, return it through a fitting welded onto the sump. Water - Just plumb it in line with the heater box. If you can't find them on this first page you're not looking hard enough.... http://www.rollaclub.com/board/?showtopic=10940 Quote
chin70 Posted October 15, 2009 Report Posted October 15, 2009 that how i done mine yesterday :jamie: Quote
driftkid23 Posted October 16, 2009 Author Report Posted October 16, 2009 hey where did you get the fitting ????? Quote
Trev Posted October 16, 2009 Report Posted October 16, 2009 Err...is that silicon hose? It won't be for long along with the turbo and rest of engine. Chin70 you have to use a solid line or steel reinforced (braided) line for the turbo feed as it has to withstand pressures in excess of 80 psi. Quote
chin70 Posted October 17, 2009 Report Posted October 17, 2009 It won't be for long along with the turbo and rest of engine. Chin70 you have to use a solid line or steel reinforced (braided) line for the turbo feed as it has to withstand pressures in excess of 80 psi. haaha yes it is it was just to get it runing Quote
