warning - non-rolla question!
and a long shot to boot ;)
I'm helping a mate get his Crown back on the road after an extended "sitting in the garden looking nice" session.
Damn thing won't start and we suspect the fuel pump isn't kicking in.
Do any of you likely lads and/or ladettes know where the fuel pump is in a 1989 Crown Super Select? Neither of us even know whether it's in-tank or what.
Following on ... I don't suppose anyone also knows the part num?
cheers,
Slapper
and a long shot to boot :)
cheers,
Slapper
Which engine is it? Toyodiy lists 1989 Crowns, for the most part (haven't checked all models/engine combos) the fuel pump seems to be in-tank
i used to own a toyota crown royal saloon, you need to pull apart the boot cover that covers the tank, then take off the tank holder, then the pump is in the tank, sittin nicely behind the tank strap, unbolt and ur laughin !
