I'm using a 1981 Corolla KE70, Malaysian "DX" model, 4K engine.
I was driving around Sunday night today.. The car in front was going
a bit slow, so I flashed my headlights at him to hurry up. When
the lever returned to its position, the headlights went off !
Turning its switch on the lever off, then on, the headlights
came back on again.
Then, when flipping my turn signal lever to the right to change
lanes, it happened again. Turning the on/off switch restored
the headlights. I had been noticing these few months, that
whenever I flipped the lever for a turn, especially to the right,
the headlights would "blip" a moment when the lever returned.
Stopped the car at the roadside, sprayed some Philips contact
cleaner into the lever contacts on the inside. Appeared to
help a bit, but the problem was still there.
So I phoned my car's wireman, and he said the complete
switch assembly - turn signal, headlights, flash and wiper
- had to be replaced, since the contact surfaces were likely
worn, or else the headlights would fail to switch on
permanently one day.
He said this happened more when using the lever on
right turns because this is the direction used most often
on the roads here - Malaysia is right-hand drive. Thus
the headlight/turn signal contacts tended to wear out
more on the right.
He could look around for a used or Taiwanese unit for
me, said it would cost at least M$100 ++.
Or he could try modifying the wiring, and installing a
separate switch for the headlights, leaving the lever
switch for it redundant. Would cost M$ 50 +.
However, I called my car's aircon man for some further info.
He said save my money - the problem could just be left alone.
No risk of the headlights failing to come on. Just turn the switch
on/off whenever the above problem arose, and it would
come on again. He said his Datsun 120Y had been having
this problem for years.
Any opinions ?
Edited by Tham
I would be replaceing the hole switch as your wire man suggested.Because one day or worse night it will fail ,not a good feeling going from head lights to
pitch black .
cheers rob
^^ ditto. Its happened to me and its not a very good feeling going from high beam, flipping down to low beam cause of an on coming car with a corner coming up - hazard lights kinda work. But jeez ;) Its like playing Russian roulette with a gun you know nothing about - could be lucky with the thing for years or it could go off the first time its used.
Having a separate switch for turning the lights on/off sounds alright as long as you
<1>can still use high/low the lights from the stalk.
<2> don't have to take your eyes off the road to turn them on/off.
Otherwise the M$100 plus will seam like cheap money well spent.
See about hitting up ebay for something or better still For Sale - Car Parts in the market place section of the Club.
pitch black .
cheers rob
Pull it apart yourself and see what the trouble is- It seems one of the wires breaks inside its plastic tube, a common problem on the KE70s. Maybe you can shorten it and re-solder it back on, or solder in a new section of wire.
Then if you can't fix it you can decide whether to install it again or buy a new one. How about the wreckers yard if $100 is too much?
I expect I'll have this problem sooner or later, my dash lights go out when I use the indicators at night, then come back on a second or two later.
M$100 equals approx AUS$32.60
That'd be Malaysian Ringgit, yes ?
Thanks. Will see what I can do, but not good at DIY work,
especially cars (most ordinary motorists over here are technically
illiterate when it comes to cars, apart from replacing the air filter
perhaps or topping up the battery water. Most repairs are left to
the mechanics or wiremen).
Otherwise I'll try to get a Taiwanese unit. I called a few shops and
they don't stock it. Called a few wreckers too, no luck. Parts for a
30-year old car are fast becoming a rarity here. Will try again next
week. A wrecker's part may cost maybe M$70 - 80.
The problem with these Taiwanese or China parts, they're not
known for reliability or durability. May last anywhere from 3 months
to two or three years, depending on your luck. (One friend installed
a Made-in-China carburettor in his Datsun 1200 and it gave out
after ..... 3 months).
At least I managed to find out its OEM part no. - 84310-12333,
for right hand drive vehicles.
Here's some China suppliers.
http://www.mac-auto.cn/list.asp?ProdID=2719
http://www.youngbooauto.com/Switch/ColumnSwitch2.htm
84310-12300 looks similar.
http://www.mac-auto.cn/list.asp?ProdID=2714
http://www.nbbona.com/product_largerimage.asp?id=5085
Edited by Tham
Yes, about that.
But Taiwanese/Chinese parts aren't exactly known to last.
See my reply above.
Otherwise the M$100 plus will seem like cheap money well spent.
Yes, I think he'll be leaving the high/low beam function
to the lever, and add an on/off switch for the headlights
and maybe parking lights as well, on the dashboard.
It's a good option actually. Maybe I will get the wireman to do
just that.
These separate switches for the headlights/parking lights
are far more reliable, really. They don't fail due to being messed
around with by the countless flipping motions of the signal indicators
and hi/lo beam flashers by mounting them all in one big complex
unit on the steering stalks, just as is happening now.
Now I know why they had a separate simple knob on the dashboard
for these lights in my old 1974 Opek Kadett 1200S when I drove one
way back in 1979 - 1980. And I had thought these Germans were
old-fashioned then !
Well, the wireman managed to install a separate switch
for the headlights.
There was a lack of space on the dashboard and the switch
was somewhat long and bulky, so he mounted it on the bottom
panel just to the right of the steering and below it.
He used one of those antique pull-pull switches. First pull
parking lights, second pull headlights, pretty long pulls, so
the knob extends about 3 inches fully.
I feel like I'm driving my late mum's 1950s vintage Austin of England !
http://www.oldclassiccar.co.uk/austina30.htm
Edited by Tham
An update on the OEM part number for the switch unit,
as informed by John of the Chinese manufacturer, Youngbooauto.com.
84310-12300 - RHD
84310-12333 - LHD
