as I'm looking to purchase a stock version of one of these but don't no a hell of alot about them, i would really like to know what i should look out for when looking at these, also stuff that can go wrong and general info that may be of some help cheers
the drfit king...
Common rust spots are the rear wheel arches, underneath the taillights, bottom of the rear windscreen.
Assuming you either wanna do one of these up or keep her "plain jane"?
well luckily my grandad and father own a elsctric hoist so score will check for that anything about that engine or electrics that are abit dodgy.. am a newbie to the whole buying cars this will be my first bought on my own accord and 2nd corolla
also check for rust buildup where the clutch cable goes thru the firewall, my ke30 had a rust problem there and it was moving when you step on the clutch.
check the chassis also, where the pitman and idle arm attaches to, crossmember mounts are also things to look at aside from what Mr. Tiger already said (I have rust in all the areas that he said)
