  • Replies 35
if you put a cam in it and get it all built and tuned right you will need a shorter (higher number) diff, eg a 4.3, or maybe even higher ratio again (but that gets complicated finding the bits and fitting them).
if you have a 4.3 or shorter and a loud exhaust then highway speeds get somewhat deafening. A five speed will improve this slightly by about 500rpm, but the best solution is for a quieter exhaust or a larger engine and taller diff.
Thats your choices there :)
Robert.
i don't c the reason for a 5spd now not if it only 500rpm difference will just fill my exhaust with hotdogs with a 286 bdure cam should still get a fer lumpy idle
