hey guys,
Hoping for a bit of help here. I recently put a 2tg into my rolla and of course expected the fuel economy to be worse than the 5k that was in there. Not this much worse though. Getting 16.5l per 100km under fairly normal driving conditions. Engine has mild cams and head work as far as I know and is running twin weber 40s with 32mm chokes. It was running rich and had machined out 34mm chokes and jets to suit then I got it rejetted with the 32mm chokes but it hasn't made a significant difference.
So all you 2tg owners what sort of economy are you getting? And what carbs are you running?
Has it been on a dyno?
You need to get it on one once you start fiddling with jetting & chokes.
Ignition timing, cam timing and even incorrect float adjustments, fuel pressures can affect your economy besides the obvious answer of how you drive it.
Check those things first before you start paying for dyno time.
  Bowler said:
He drives it like a grandma...so no realy question about too much right clog... :)
mostly grandma style driving but occasionaly the intake noise gets the better of me and its gets a fair amount of 'right clog' as you put it.
