ka24 block is cast iron. On the business end.... cams r direct acting(no rocker arms)
For daily use, a KA torque actually makes it a pleasant drive... and it can be quiet. Unlike those noisy small displacement high revvers, annoying exhaust & induction noise and having to rev the piss outta it to get any grunt. Lotsa shifting, short gears too. KA is a different animal.
Just because KA makes more torque lower to midrange, dosen't mean it won't rev/pull past 7000... thing is, no need to.
KA has posted ridiculous street and drag ETs, especially considering the mods used.
High mileage KAs done well over 400hp atw + a robust 400+ft-lbs tq, std innards.
Enough to pee-ur-pants in street rolla.
Over 500hp & tire-shredding 550+ ft-lbs tq, std head/cam/intake, only piston/rods added.
"Truck" motor or not, KA can be deadly
Dunno what RZ can do on std innards, but I suspect similar potential, if ya wanna keep a rolla all toyota. There was a nice 2RZ powered street rolla detailed on 3tc.com - pistons/rods/std head & cam. At 26psi went 9.8sec. Got an amazing 37mpg too! That is what 'truck torque' can do 4 u :)
RZ engines can (when worked) produce a crap-load of power. Take a look at the 3RZ turbo KE wagon on here.
Good thing about "truck" engines is that they tend to have quite strong blocks :-)
^^^ yes...and no.
Alot of people choose to hang the gearbox lower to make it clear,
it points your engine and everything up in the front a bit, but this is how the majority of conversions are done.
The other option is to mod the tunnel to suit, which includes the brace the front of the seats sits on.
Yet another option is a bluebird series 3 gearbox, a much shorter design, but weaker also,
this is a popular option with the datto boys.
yeah ok thanks for the info, I was going to use my ke70 as a basis for the mounts and i am guessing that it has more room under it. So this bluebird box does it have the same mount?
only thing i had to do to my ae71 to fit the ca box was cut the tunnel back a bit more to fit the shifter through... no clearance issues in the tunnel whatsoever
yeah I figured that, I was under the impression though the earlier corollas have a smaller tunnel again.
