hey guys..
its got me stuck.. people say yes its bad and no its ok..
is compressor surge actually bad for your turbo or is it just a myth..
I'm guessing its not good cause its trying to turn the turbo the opposite way its spinning..
cheers
  • Replies 38
Have heard many things but i really don't think its that bad unless your running huge amounts of boost. Know plenty of people that have been running stockish setups for quite some time with no problems. Its also argued that theres a difference between flutter and actual compressor surge but I'm not entirely sure on that one...
The rapid deceleration/fluctuations in speed of the compressor would put a lot of pressure on the turbine and the shaft would it not? Especially axial thrust on the shaft, which would cause premature bearing wear.
  irokin said:
*sniff sniff* I smell bullshit.
x2
I'm not going to write an essay on why its not good, I'll just leave you with one point.
If dosage/flutter/compression surge is ok, and BOV's are not really neccessary, then why does basically every factory turbo car have factory fitted BOV? :P
Actually, can anybody tell me of a factory turbo car that doesn't have a BOV? Seriously I want to know!
Edited by Taz_Rx
  Taz_Rx said:
x2
BOV from factory are for emissions. They also do alot of strange things, RB20DET's stock BOV actually leaks on purpose. All factory turbo cars will have a BOV, cause they will plumb back, just for emissions.
Compressor surge is bad, as it stalls the compressor wheel. Does take alot of PSI to kill one though (40+ lbs) So, someone running small boost I.E 7-12psi, wont have a drama with it. Unless, its a cheap chinese turbo. I have seen compressor surge kill a chinese made one, was indeed funny.
IMO, factory plumb backs > External gating. The noise is just wank.
OK lets just get one thing straight... Compressor _surge_ is NOT the same as MAD FLUTTERZ/does. True comp surge is very violent and seldom seen in cars unless you chose some bizarre miss matched compressor/turbine. Its more of a popping noise when you are on the accelerator. People seem to have confused the two because "I guess the flutter is a surging kind of sound".
Chinese turbos will fail regardless.
ET pulsar/exa for a start and there are several more.
