awvg Posted September 22, 2009 Report Posted September 22, 2009 hay guys as i have recently blown the rings on my worked 5k i was looking into upgrading the engine to the typical 4age etc. i was hopeing to use a donor car that already has the running conversion to save time and headaches and transplant the running gear into my 35 as it doesnt have any rust and has already had the brakes and suspension upgraded. My problem is i can find plenty of ke70's out there but not many 35's or 55's for a worthwhile price. what i was wondering is how compatiable are the two cars, would it be a simple bolt out bolt in or are they so different it wouldnt be worth my while. cheers andre Quote
Sam_Q Posted September 27, 2009 Report Posted September 27, 2009 awvg said: hay guys as i have recently blown the rings on my worked 5k i was looking into upgrading the engine to the typical 4age etc.i was hopeing to use a donor car that already has the running conversion to save time and headaches and transplant the running gear into my 35 as it doesnt have any rust and has already had the brakes and suspension upgraded. My problem is i can find plenty of ke70's out there but not many 35's or 55's for a worthwhile price. what i was wondering is how compatiable are the two cars, would it be a simple bolt out bolt in or are they so different it wouldnt be worth my while. cheers andre the whole engine/clutch/gearbox bolts right in Quote
LittleRedSpirit Posted September 27, 2009 Report Posted September 27, 2009 Sam_Q said: the whole engine/clutch/gearbox bolts right in With K motors yes, but if you find ke70 with a 4age conversion and want to fit that, you are sorely out of luck. I think the ke70 would handle better right pout of the box anyhow, so youd be mad to change shells. Quote
TE278U Posted September 27, 2009 Report Posted September 27, 2009 awvg said: hay guys as i have recently blown the rings on my worked 5k i was looking into upgrading the engine to the typical 4age etc.i was hopeing to use a donor car that already has the running conversion to save time and headaches and transplant the running gear into my 35 as it doesnt have any rust and has already had the brakes and suspension upgraded. My problem is i can find plenty of ke70's out there but not many 35's or 55's for a worthwhile price. what i was wondering is how compatiable are the two cars, would it be a simple bolt out bolt in or are they so different it wouldnt be worth my while. cheers andre A 4age setup from a Ke70 will not bolt straight into a 35. you will need to modify your engine mountings, clutch pedal setup, and likely a custom tailshaft and gearbox mounts. There will also be some mucking around with wiring and cooling as with most engine conversions. There would be only minor benefits buying a ke70 that has been converted and then puting it in a ke35. Dave Quote
KEI069 Posted September 27, 2009 Report Posted September 27, 2009 The ke35 also has a steering box doesnt it and the ke70 has a rack and pinion so there could potentially be a drama with sump and engine position Quote
Sam_Q Posted September 27, 2009 Report Posted September 27, 2009 oh sorry I misread the original question, what you can use out of the ke70 is the following: engine clutch gearbox, gearbox mount, loom, ecu and possibly the metal line on the firewall for the clutch. As above you will need custom mounts for the engine which I can possibly help you with. Quote
awvg Posted October 12, 2009 Author Report Posted October 12, 2009 (edited) thanks alot for your help guys much appreciated .. just looking for the donor as my car is already fully set up with suspension and brakes and is a very clean shell. cheers andre Edited October 12, 2009 by awvg Quote
