Raven Posted March 19, 2010 Author Report Posted March 19, 2010 You can use a RRFPR in a non boosted setup, if no boost line is connected fuel pressure is referenced to atmospheric pressure. The Malpassi carb one I have is adjustable. Biggest problem is they are a return style regulator, so NEED a return line.... Otherwise they will just supply full pump pressure. A dead-head style reg (Holley type) is needed if you don't run a return line. Yeah I had a look tonight and its adjustable but the return is sealed up and I don't really want to have to plumb in a return line to the tank so I'm going to get a low pressure electric carby fuel pump next week through work. It runs 2.5psi-6psi, so should be a better setup than whats on it and maybe I can get the damn thing to run right. :) Quote
Raven Posted March 20, 2010 Author Report Posted March 20, 2010 Off to do some rewiring today for the Crane Digital Multi-Spark Ignition, due to losing power a few days ago. Quote
Raven Posted March 21, 2010 Author Report Posted March 21, 2010 (edited) ...and rewired! Tidied up the engine bay a little too. Whoever the previous owner had got to wire up the Crane Ignition was a butcher! Still need to get that fuel pump though :jamie: Edited March 21, 2010 by Raven Quote
Karllos Posted March 21, 2010 Report Posted March 21, 2010 geez your updates are so quick they don't give people a chance to reply :jamie: Sounds good from the movie too. Karl. Quote
Raven Posted March 21, 2010 Author Report Posted March 21, 2010 People should look more often :jamie: Quote
13BT_KE20 Posted March 21, 2010 Report Posted March 21, 2010 nice work mick, bet you can't wait to have this as the daily rather than the fagna Quote
Raven Posted March 21, 2010 Author Report Posted March 21, 2010 Mostly definitely. Though the Fagna has been a pretty well reliable bus (except for the fuel pump shitting itself, then again, that is 16 years old), it has served its purpose well. :jamie: Quote
Raven Posted March 22, 2010 Author Report Posted March 22, 2010 Bought my fuel pump today! Now I can piss off the fuel regulator (will use it on the KE25 for the Rotary conversion) and plumb it all in properly :jamie: Quote
Taz_Rx Posted March 22, 2010 Report Posted March 22, 2010 Bought my fuel pump today! Now I can piss off the fuel regulator (will use it on the KE25 for the Rotary conversion) and plumb it all in properly :jamie: You going EFI for the rota? Quote
Raven Posted March 23, 2010 Author Report Posted March 23, 2010 Nah, i'm going for a big arse weber once it's all been approved with the stock setup. Quote
13BT_KE20 Posted March 23, 2010 Report Posted March 23, 2010 wont need that reg then can sell it, worth about $80-100 last time i looked : ) Quote
Taz_Rx Posted March 23, 2010 Report Posted March 23, 2010 wont need that reg then Agreed, thats why I asked. Quote
Raven Posted March 23, 2010 Author Report Posted March 23, 2010 (edited) All depends on what fuel pumps I use and what powr I'm chasing I guess. Gonna re-check the fuel regulator tonight before I get stuck into changing the fuel pump if I need to. Edited March 23, 2010 by Raven Quote
Raven Posted March 23, 2010 Author Report Posted March 23, 2010 Regulator did jack shit. Fuel pump change made it marginally better. I'm now thinking the cam isnt dialled in correctly which could be causing my issues. Who wants to dial it in for me? Will pay in beer or bourbon! Quote
Taz_Rx Posted March 24, 2010 Report Posted March 24, 2010 All depends on what fuel pumps I use and what powr I'm chasing I guess. Nah man. Carbys only need a low pressure pump and reg. There's no reason why you would need a RR EFI pump for a carby fed motor...... unless it was turbo'd, but then you would use the correct carby RR malpassi. To check you cam timing remove the #1 plug so you can sit a long screw driver or something on the top of the piston so you can feel its position. Then with the "engine hat" off watch the rockers for #1 while you turn the motor back and forward and try and see if the cam timings a bit off. ;) Quote
