Cool. There's a pic in the faq I took next to a k40 & k-t50 that'll give you some idea on position. Mines still sitting in the shed unused.
Yep, had a look at that, just seen a few different shifter housings. Guess this one was modded for the rearward housing.
What up Coilovers!
HSD Coilover Kit. Thanks to Haydoss
7Kg springs, will be swapping them at some point for some 4Kg's from work. Also some Wilkinson Suspension Castor/Camber tops.
RA60 Vented discs and MX62 Calipers with TRW high temp pads.
Edited by SLO-030
Looks good dude! Can you measure the xt130 hub thickness for me? Still considering going down this route if i can get em to fit better..
Good to see you out and about in this the other day also!
