Aww.. I enjoy your tight spot Ry ;)
Glad to see you got that thing fixed.. Far out, surely you WILL run out of ideas with this car, wont you?
Or is that a stupid question?
:P
:P
I know you do Sam. I've got it sitting in the shed if you want some MOAR!
Annnnd, probably the latter.
Got some rust coming thru already. Not breaking thru, just bubbles. In areas that there wasnt before. FML. Rebuild #2 already?
Leccy dizzy going in tomorrow.
Hoping to save up some $$$ and get it dyno tuned at West Torrens. Play with carb jetting and ignition curve.
Bit hard to do it off a dyno when noone has a clue what the specs of the cam are :glare:
Edited by SLO-030
Maybe the Tullamarine Freeway back here in Melbourne can Dyno the Power for you. :P
Good to hear/read you got this Green Monster back to shape. :)
Josh :cool:
Edited by ewt
Dizzy in. Misses a bit at points in the rev range.
Have on order:
Dizzy Cap
Rotor Button
Leads
Plugs
Plug Tube O-rings
Gap the plugs and well be set :D
  On 3/20/2011 at 9:15 AM, SLO-030 said:
Replaced the rear uni. No more tight spot. No more vibration. YAY.
Replaced the rear uni. No more crossed up roller bearings, driveline vibration, epic clunk. YAY.....sorta.
Have on order:
Dizzy Cap
Rotor Button
Leads
Plugs
Plug Tube O-rings
Got Everything done today.
Did it all for about $75
Plugs gapped to 0.8mm.
The old plugs i pulled out were great after 15,000km. Nice tan colour. Not too rich, not oily. Nothing. Shows the engine is in good condition
and running well. WIN!
Edited by SLO-030
Ram tubes are directly bolted to the inlet of a weber carb.
This will purely be for looks only doing it the way you're doing it as it can't ram air directly into the carburettor.
You'd be better off machining up one big ram tube to cover the inlet of the stock carb and running a divider down between the primary and secondary throats, so they get their own shot of air each. :)
