rollas22 Posted September 12, 2009 Report Posted September 12, 2009 OK, so I'm doing a rotary conversion on my ke20. I have a RX7 series 1 brakebooster to go in. Ive cut away all the un-necessary sheet metal in the way. Have got to this problem, i have to enlarge the 40mm standard ke20 hole to 50mm to accomodate the rx7 booster, Just wanting to know what sort of tools i will require to achive this? Or will i be beter of using a KE55 booster? Quote
philbey Posted September 12, 2009 Report Posted September 12, 2009 A hole saw will do it, they come in 52mm diameter. Quote
StasIII Posted September 12, 2009 Report Posted September 12, 2009 I've used a dremel to enlarge the hole. Quote
rollas22 Posted September 13, 2009 Author Report Posted September 13, 2009 All sorted! managed to make it fit today with a bit of perseverance, fits in snug next to the clutch master cylinder. Few more things to do an it shud be nearly ready to hit the streets Quote
