Arrrrhhh :jamie:
5 speed box has locked up in 3rd gear.
Does anyone have an exploded view diagramme of the k50 or a workshop manual?
Any suggestions on how to fix it, or what the likely cause of the lockup was??
cheers
I had an old box do that once on the highway, was in a bad mood and slammed it in third and it stuck, had to put both feet flat on the floor and yank at the gearstick till it popped in to neutral.. and the box was pretty well f@$ked after that, kept popping out of gear on the highway..
Thanks for the input ... will try and pull it open and have a look see
Anyone got a K50 they don't need ????
