From reading it I assume he used RA40 LCA's & steering arm
well at the moment i have used th ra40 steering arm and strut on the ke30 ball joint and LCA
i think the ra40 LCA and the ke30 LCA are the same LENGTH??????
I have also been told that ra40/ke30/ke55 all have the same LCA lengths
Yeah i sorta fort that
but i need a LCA some where between 10mm and 25mm shorter
coz the moment i have camber problems /---\ lol
so i need to no what LCA are interchangeable (if that how you spell it lol)
so then i can go to the reckas and do some meserments :lol:
If you need to reduce camber, get some KE70 LCA's.
Esev boys use the KE30/55 LCA's (same as XT130) for around -2.5degrees. So the KE70 LCA's in KE30/55 should remove 2.5 degrees camber.
well i just been told ra40 , ke30 , ke55 and xt130 LCA arms are the same lenght????
:P i now need a tape measure to fing out
i will measure them all and put up some measurements :lol:
nexted tym i go down ill measure these and see
ke30 mm
ke55 mm
ke70 mm
xt130 mm
ra40 mm
ra60 mm
cheers shaun
Don't know how relevant this is but if you go to a "real" wheel aligner (not the tyre shop cowboys) they can do a strut bend. I had a Datto 1600 which suffer from negative camber cause of the indie rear ends. Down to the man who can do these things and magic, no chopped out tyres.
RA60 brakes are ventilated.
I'm planning on putting them in my KE30. Might get some adjustable camber tops for adjustments.
where can i get these from (adjustable camber tops)?????????
and how much????
