chadd1981 Posted September 9, 2009 Author Report Posted September 9, 2009 okay i have found a 3 speed auto box out of a KE55. Now my question is are the output splines that same from the manual gearbox to the auto?? also are the gearboxes the same length?? Quote
spoon Posted September 9, 2009 Report Posted September 9, 2009 i have a ke70 auto gearbox if you want it also - just have to seperate it from the 4k... with everything to suit. pm me if you want it - you can have it free Quote
Evan G Posted September 9, 2009 Report Posted September 9, 2009 i been in a auto hiace/townace auto they must be a 4 speed, (townace 5 or 7k?) doing 100kph its smooth engine isnt revving at 895830945093489453 rpm like a toyoglide/trimatic Quote
chadd1981 Posted September 11, 2009 Author Report Posted September 11, 2009 i have got a couple more questions for you guys that i need to get my head around before going ahead with this conversion. What size transmission oil cooler would i need to keep the temp down?? what sort of temp do the auto boxes run at normally?? I want to get everything sorted out from the word go so i don't have any problems once i start doing it. Any info would be a great help. Cheers Quote
67Rolla-Ken Posted September 11, 2009 Report Posted September 11, 2009 Does your Radiator have a cooler for the box in the bottom?? I thought all Rolla rads had that? Quote
Evan G Posted September 11, 2009 Report Posted September 11, 2009 normal temp is around 80degrees and you don't need a oil cooler but there good if you plan to stallies all day Quote
Rolou Posted September 11, 2009 Report Posted September 11, 2009 Hi, I have a auto gearbox complete from a 7K van, has torque converter , flywheel and pipes will bolt to any K motor, has done 24k. Motor is in my sprinter. Price $500 ex brisbane cheers Lou Quote
philbey Posted September 12, 2009 Report Posted September 12, 2009 Chad, Ken is bang on correct, Automatic corollas have a cooling loop through the bottom radiator tank, which should do you fine. Otherwise, any old basic tranny cooler will be fine and probably much more cooling capacity than the stock radiator. Quote
chadd1981 Posted September 13, 2009 Author Report Posted September 13, 2009 Thanks Guys, I don't have the corolla radiator as it is still running the stock sierra radiator. I think that i will still run a oil cooler just to keep the temp down as i will be using it off road in low range etc and it may get hot working down low. Quote
libbor Posted April 2, 2010 Report Posted April 2, 2010 Hi Rolou, Do you still have the auto box? is it a 3 or a 4 speed Cheers Libbor Quote
MRMOPARMAN Posted April 3, 2010 Report Posted April 3, 2010 philbey said: 1968-1983 corolla's with Auto gearboxes will fit, as long as they had a K engine in them. The early models, 68-72 have the 2 speed toyoglide - probably not what you want. The Later models, KE30, KE55, KE70 ran a 3 speed trimatic box which is probably what you want. Any toyota wrecker should have one, just make sure it's off a K engine and you'll be fine. they ran toyoglides into early ke30's aswell. 67Rolla-Ken said: Nothing wrong with my Toyoglides.... cept the 85km/h top speed :S had my stocker ke25 (with toyoglide and sunvisor) up to 95mph on the speedo. took ages to get there and i had to draft an RA23 celica on a downhill section (of a racetrack :D ) to do it Quote
