Reaper_Mobb Posted August 26, 2009 Report Posted August 26, 2009 hey guys, i drove about 250 km the other day and by the end of it the car was finding it hard to idle in 1, 2 or drive (its an auto), got REALLY bad about 10km from home, got ho,e and let her cool down. poped the bonnet and the dizzy cap was 1/2 off not sure for how long but i fixed it up and thought nothing more of it.... oops... ran rough the next day, so i took another look, points a little dirty, but centre point was FRIED and had black burnt looking plastic all over it and a "chipped" looking contact. i cleaned it all down. i check the plugs and gave them a scrub (will be getting new ones this weekend). is there anything else i should check? its stock as a rock Quote
Felix Posted August 26, 2009 Report Posted August 26, 2009 Get a new cap, rotor button, and a set of points when you buy new plugs. Quote
Reaper_Mobb Posted August 28, 2009 Author Report Posted August 28, 2009 picked up the gear this arvo... the cap is to small and the leads look all wrong... i got them from repco and the guy said they where for a 4k. can anyone tell me what brand/model/whatever i need to get? budget about $50-$80 for both (not each) Quote
SLO-030 Posted August 29, 2009 Report Posted August 29, 2009 I have a feeling there are 2 different types of dizzy caps. the one to suit the nippon denso dizzy and the other to suit a Bosch. Quote
BReNt Posted August 29, 2009 Report Posted August 29, 2009 Does the car idle alright when it's in neutral?? Quote
78ke30 Posted August 31, 2009 Report Posted August 31, 2009 SLO-030 said: I have a feeling there are 2 different types of dizzy caps. the one to suit the nippon denso dizzy and the other to suit a Bosch. this is correct, if your not sure what your current dizzy cap/rotor button is is easy way to do it would be just take it in side and get it matched ngk should cover ur points/plugs/leads if ur still having troubles look in to ur coil as well Quote
Reaper_Mobb Posted September 1, 2009 Author Report Posted September 1, 2009 BReNt said: Does the car idle alright when it's in neutral?? yeah its "ok" i got the right cap now and ngk plugs, old leads are ok but i got a new set for spare just in case. runs good not but looks like the timing is advanced... i don't have the gear to fix it :P 78ke30 said: this is correct, if your not sure what your current dizzy cap/rotor button is is easy way to do it would be just take it in side and get it matched ngk should cover ur points/plugs/leads if ur still having troubles look in to ur coil as well yeah it a Bosch dizzy, the first cap was Bosch but to fit the other dizzy. now i have champion to fit Bosch... Quote
78ke30 Posted September 1, 2009 Report Posted September 1, 2009 Reaper_Mobb said: yeah its "ok" i got the right cap now and ngk plugs, old leads are ok but i got a new set for spare just in case. runs good not but looks like the timing is advanced... i don't have the gear to fix it :P yeah it a Bosch dizzy, the first cap was Bosch but to fit the other dizzy. now i have champion to fit Bosch... yeah sounds right, Bosch make dizzy and caps as with champion they just make caps, points etc.. Quote
