demuire Posted June 7, 2005 Report Posted June 7, 2005 I can almost guarantee it won't "bolt up"... Quote
z|gen Posted June 7, 2005 Report Posted June 7, 2005 iv never known toyota to put a letter before a digit..if you look at all the toyota engines made..there is always a digit(s) before the letters.. Quote
20V_KE35 Posted June 7, 2005 Report Posted June 7, 2005 this is because the engine is share engineer with daihatsu...dauhatsu engine start with latter Quote
z|gen Posted June 7, 2005 Report Posted June 7, 2005 interesting, because most of daihatsu's engines iv worked on are infact toyotas.. Quote
Mr Revhead[RL] Posted June 7, 2005 Report Posted June 7, 2005 well I'm know 2tg expert, but damn that looks so much like one..... Quote
Super Jamie Posted June 7, 2005 Report Posted June 7, 2005 z|gen said: interesting, because most of daihatsu's engines iv worked on are infact toyotas.. not surprising, consdiering toyota have owned daihatsu since 1972 a paseo uses a 5e-fe motor, 1500 but otherwise pretty similar to a 1300 4e from a starlet. it's the "big block" starlet engine and i've played around with a 4e-fte, apart from the fact you can't get rwd gearboxes or bellhousings for them, nobody makes spigot bearings to suit, and nothing bolts across to a K motor either Quote
z|gen Posted June 7, 2005 Report Posted June 7, 2005 could always go with a custom bellhousing to T50 g/box.. Quote
Super Jamie Posted June 7, 2005 Report Posted June 7, 2005 why bother, a 4age would be worth as much as the bellhousing, and it's a better motor than a 4e to start with Quote
