couldnt help myself sold my ca18 ke30 and not even two weeks later found this and so the story begins. Bought it as a crahed car that looks like was owned by and elderly lady has about 110'000kms. Plans are either 3rz or 1jz depends which comes up for the right price wont be going anything to serious as was intended as a daily driver so maybe something around 300-350rwhp hopefully reliable.
Diff is a early hilux 2wd the shortest or them which is only slightly longer than the standard corolla one so will fit without cutting, just had to move the spring mounts out 20mm each side. The diff i got came with 4.8 diff gears so if anyone has something around 3.7-4.1 ratio may be interested.
Front brakes are peugot rotors with about 6mm machined off the outside diameter, ln106 hilux 4 spot calipers, xt130 front struts and hubs i think i shortened them about 70mm and used st184 celica inserts. Coil over sleaves that i got through fulcrum which will be used with standard rubber tops and bearings. Camber will be achieved with sigma control arms which i already had with new bushes and ball joints should give me about 2.5 degrees depending on height.
Brake master cylinder will be vk commodore which is 15/16 bore same as hilux diff and same as ln106 calipers which should fit straight on the corolla booster.
So anyone got a motor for me at the right price?
Edited by sleepercorty
