KE70slider Posted August 20, 2009 Report Posted August 20, 2009 hey guys does the xt130 single piston caliper have the same bolt spacing/snd rotor spacing as the twin piston caliper i think i have xt130 single piston calipers in my car atm. i am just unsure as to wether i can bolt up some twin piston brakes cheers in advance Ryan Quote
mikey_m Posted August 20, 2009 Report Posted August 20, 2009 hey guys does the xt130 single piston caliper have the same bolt spacing/snd rotor spacing as the twin piston caliper i think i have xt130 single piston calipers in my car atm. i am just unsure as to wether i can bolt up some twin piston brakes cheers in advance Ryan Yes the Twin definatly just bolts straight on, I have just done one myself. Quote
BlindKidSeeks Posted August 20, 2009 Report Posted August 20, 2009 (edited) from what i've read, the master cylinder/ brake booster will need an upgrade with twin piston. Edited August 20, 2009 by BlindKidSeeks Quote
mikey_m Posted August 20, 2009 Report Posted August 20, 2009 from what i've read, the master cylinder/ brake booster will need an upgrade with twin piston. You don;t NEED a new master it does actually work if $$$ are a bit prohibitive when you do it, you will just have to push the pedal further. But like most will agree, this is not really a nice feeling having to push that far, a Pajero master bolts straight on and has no issues pedal feel is what you'd expect. There is a thread in General Mechanical all about this and covers the entire conversion and parts required including part numbers. Have a search you'll find it easy as. Quote
BlindKidSeeks Posted August 20, 2009 Report Posted August 20, 2009 You don;t NEED a new master it does actually work if $$$ are a bit prohibitive when you do it, you will just have to push the pedal further. But like most will agree, this is not really a nice feeling having to push that far, a Pajero master bolts straight on and has no issues pedal feel is what you'd expect. There is a thread in General Mechanical all about this and covers the entire conversion and parts required including part numbers. Have a search you'll find it easy as. awesome mang... i'm going to look into this.. as my Kaysev has a long pedal as it is... Quote
silverra23 Posted August 26, 2009 Report Posted August 26, 2009 My KE35 feels over braked with the Pajero Master Cylinder on it.. Mine locks a front brake very easily now which is not that much fun on the track! I am not sure if its the master or something else going on, but it might be worth doing without the master first and seeing how you go. Quote
mikey_m Posted August 26, 2009 Report Posted August 26, 2009 My KE35 feels over braked with the Pajero Master Cylinder on it.. Mine locks a front brake very easily now which is not that much fun on the track! I am not sure if its the master or something else going on, but it might be worth doing without the master first and seeing how you go. You can always stick a bias valve on the rear line, and play with the balance an then not press so hard. :P I find it loks easy too but getting used to the feel has been my solution so far Quote
