Taz_Rx Posted August 19, 2009 Report Posted August 19, 2009 3lt petrol, not deisel? That much torque at 1100rpm is just rediculous. I bet you they've sacrificed a lot of top end power for that torque, bring me back to the agument of starving the 4k in the top end. Yes you would need to use a gasket on either side of the spacer, which just makes matters worse. IMHO you're stupid not to build a hybrid (3K block/4K head) when you have the option over a spacer. Free/cheap turbos are good,....... but free/cheap un-suitable turbos will just cost you power!!! :) Quote
Evan G Posted August 19, 2009 Author Report Posted August 19, 2009 3lt petrol, not deisel?That much torque at 1100rpm is just rediculous. I bet you they've sacrificed a lot of top end power for that torque, bring me back to the agument of starving the 4k in the top end. Yes you would need to use a gasket on either side of the spacer, which just makes matters worse. IMHO you're stupid not to build a hybrid (3K block/4K head) when you have the option over a spacer. Free/cheap turbos are good,....... but free/cheap un-suitable turbos will just cost you power!!! :) its a petrol turbo it was free :y: turbo 1.5L turbo running on a 1.2L? 1 more cylinder feeding the turbo but .3L less capicty? fresh rebuild of the 3k with a 4k head maybeeee valve springs, cam? efi manifold? wolf 3rd? ($1300 :lolcry:) Quote
Taz_Rx Posted August 19, 2009 Report Posted August 19, 2009 its a petrol turbo it was free :) turbo 1.5L turbo running on a 1.2L? 1 more cylinder feeding the turbo but .3L less capicty? fresh rebuild of the 3k with a 4k head maybeeee valve springs, cam? efi manifold? wolf 3rd? ($1300 :y:) Try it if you want, but don't be suprised if it goes like shite. Yeah it'll boost quick, but thats all it would be any good for. I currently have a T25G (2lt SR20 turbo) and I'm pretty over how its too small for my 5k. Also had a 2lt WRX turbo which was near perfect size for a 4k. There's a little more to it than just saying its only 300cc off what it was on. Out of interest, whats the peak power RPM of said twin turbo BMW? Quote
Evan G Posted August 19, 2009 Author Report Posted August 19, 2009 (edited) Max Power: 225kW @ 5800rpm Max Torque: 400Nm @ 1300rpm Max Speed: 250km/h 0-100km/h: 5.7 seconds you just sink in your seat and count how many times the traction control light flashing try source another turbo and do a 3kc twin turbo? :) Edited August 19, 2009 by Evan G Quote
Taz_Rx Posted August 19, 2009 Report Posted August 19, 2009 try source another turbo and do a 3kc twin turbo? :y: ...on a 5k maybe. And it would go a lot better (once you got boost) than just the one. I nearly did a twin turbo 4k with 2x CT12's. Thats how small they were. :) Quote
Evan G Posted August 19, 2009 Author Report Posted August 19, 2009 i also got a turbo from a 3L diesel with the veriable vane wastegate? should spool quickly but it wount have excessive exhaust back pressure becaue engine is so small? Quote
Taz_Rx Posted August 19, 2009 Report Posted August 19, 2009 i also got a turbo from a 3L diesel with the veriable vane wastegate? should spool quickly but it wount have excessive exhaust back pressure becaue engine is so small? That turbo would probably be a lot more suitable. :y: General rule of thumb with deisel turbos on a petrol motor is you can halve the capacity because the petrol motor does twice the RPM. This also answers your bottom question too. VNT "wastegates" aren't actually a wastegate, they are a vacuum operated solenoid which works completely didfferent to a wastegate. Was only a couple of weeks ago that I explained how these work in a thread in the general mechanical section. See if you can find it cause I can't be bothered re-typing it again. If you're lucky I'll find you a link soon. :) Quote
Teddy Posted August 19, 2009 Report Posted August 19, 2009 Time to bring out the 1HZ and put her into a rolla. Yes sir. Yes. Sir. Quote
seabiscuit Posted August 19, 2009 Report Posted August 19, 2009 I think Evan_G needs to add Taz_Rx on MSN! Quote
Taz_Rx Posted August 20, 2009 Report Posted August 20, 2009 And its reason like that why Taz_rx doesn't have an msn account!!! :) Quote
machg Posted August 20, 2009 Report Posted August 20, 2009 I have a surplus Falcon throttle body EFI $50 plus postage, apparently it will bolt onto a weber carb mount. Quote
