I have a ke35 with the late type dash, however the speedo does not work, it is definately not the cable as the odometer happily ticks over.
My question is Even though the clusters are different can I just swap the sppedo unit itself between the late and early model dash?
Only asking this as I have a spare early model dash in a car I am wrecking,
Thanks Guys.
Edited by ke30dude
All good :D
I had a bit of spare time because the boss was not up yet.
The clusters are the same it just looked different because my early one didn't have the clock.
Swapped the speedo in, along with the cable because someone had repaired the clip on the end with masking tape.
While I was at it I realized that someone had butchered the wiring to make the lights behind the speedo work, it appears that the dimmer cable had been unplugged lol, repaired the harness and plugged it back in.
More off my before RWC list :D
