Hey guys,
I'm new to the forum.
I have a 94 seca rv, and just bought an 81 ke70 and rolled 83 Corona with a cammed and twin webbered 18rg and 5spd..
Will post pics soon as i get around to it.
Anyway, was looking at slapping the 18R outta the corona into the ke70 for a bit more more poke.
I haven't had time to get around to measuring anything up yet and thought I'd just ask to see if anyone had done this and if they could give me a few pointers to save me time...
-Can I use the engine mounts and gearbox mounts?
-Can I use the front discs and calipers? (I haven't looked but id imagine they are bigger!)
-What are the upgrades needed to pass regs in qld?
Thanks in advance
Josh,,
josh - you probably wont be able to register this conversion, becasue the carby version of the 18RG ended production around 1979-1980, and the KE70 started production around 1982/83.
Me personally - I'm putting a turbo 18R-GEU in my KE70, but i have already cleared this with an engineer, cos the 18RGEU was made up until 1983/84, which overlaps with the KE70 production.
As for ease of fitment - i am expecting to require custom engine mounts and gearbox crossmember. I'm also using a W55 gearbox for extra strengths.
In short - don't bother.
Thanks for the info The Witzl..
But it didn't really make sense.
(So at the moment I think I will still go ahead with the build.)
The '81 ke70 is a carby'd 4k right..
And the '83 18r was fuel injected before the Webbers and cam was fitted.
If I'm fitting the engine, I thought it only had to comply with the regulations of the body it's fitted to, along with modifications to keep everything within performance tolerances.
But please correct me if I am wrong.
But anyway,
I imagine the engineer required you to upgrade the brakes?
-Bigger discs and calipers up front
-Rear discs
-Matched master cylinder
I can sort out a set of engine mounts and gearbox mounts myself, then get them engineered.
How did you go with tailshaft length?
Thanks in advance
Josh,,
custom tailshaft for me - i have a volvo diff also... so everything is custom in mine.
Best speaking to a signatory engineer on this planned conversion - it could be allowed, and it might not be. Best off asking the guy who would have to sign off on it (thats what i did, but I'm in NSW).
