rwdrolla Posted May 30, 2005 Report Posted May 30, 2005 i've been offered a 4k and t-40 for $100 or so, the 4k with a cracked headgasket, and some smoke. they guy is going to help me put em both in. how hard is it to do an auto - manual conversion? and what can we do to the 4k for a bit more power? besides webbers? Quote
Xany Posted May 31, 2005 Report Posted May 31, 2005 if thats a t-40 gearbox, it had better have an adpater plate on it for the K block....otherwise you're gunna have trouble fitting that. whats wrong with your old 4K? you can mod the cams, exhaust and if you have the money put some new rings and bearings through it. You can also port the head, bigger valves and double valve springs....it all depends on how far you wanna go. Quote
