There is one for sale with plugs that have been cut off approx 10cm from digital dash.
My question is, will this be possible to wire into my ae71, ive decided on an ae82 loom.
Travis
the wiring would be possible if you have the correct loom that the dash is made for
you will need the wiring diagrams and a decent knowledge of electronics
You also need the specific fuel sender and (I think) oil pressure sender. Fuel sender not that easy to get.
I think the reason they get passed on.
The pinouts are around on the net so that bit shouldn't be too hard.
Darn, Alright cheers.
Yea I could have wired it in, but if I have to look for certain senders, I wont worry unless one with senders and loom turns up.
Travis
