hey lads called repco and the fuel miser rebuild kit an-107 suits from 72 onwards, so I'm rekitting my 3k carb in about an hour at work, just ripped the jets out of a 5k they are 108 primary 153 secondary. The 3k are 100 primary and 147 secondary. If i put the 5k jets in I'm assuming no ill affects other than running richer biut should i change to the 5k power valve and idle jet aswell or keep the 3k ones as is? Anyone run a 3k carb with 5k jets and how did it go'? Cheers
All you can really do is try it and see. Only takes like 5 minutes to rip the top off the carb for a jet change.
I wouldn't change all the jets at once. You'll have really no idea of what is working better or not.
In order jets to change/experiment are:
1: Idle
2: Primary main
3: Power Valve
4: Secondary Main
