You can definitely use the stuff you have there. JDM or ADM doesn't matter. Only problem is if you try to use late bigport sensors / injectors etc on an early bigport loom. They have different plugs and won't fit. "Early" plugs are generally yellow or green, with greyish injector plugs. i.e. what you have.
But that loom is a mess. If you can wait, I would recommend sourcing a rear wheel drive loom from somewhere. They come up often enough and don't generally cost much.
Alright thanks,
If I can find one for a good price then yea I will definately go for it, but I will hold off on the wiring then for a couple of months, ill do engine and running gear and suspension in the mean time.
Travis.
