KE70_Rolla Posted May 22, 2005 Report Posted May 22, 2005 Ok so yesterday and today I was out in Stanthorpe on my parents property (dirt track most of the way (ofcourse I would've done a silly thing or two to see what it had) on the way back the idle was fine, idled at about 800, got to my little brothers godmothers house to see how she was, had to move the car out of the road of another car, it was fine, had trouble as usual trying to keep it idle when first kicked over, but it was fine, got one the road again, still fine, on they way home it was idleing a bit low, went out again and it stalled, but was going down fear and just coming off of the clutch so it kicked over again, then it just stopped idleing pretty much and was either stalling or idleing at 250 roughly, eventually got sick of it and pulled the choke out a bit to keep it going when stopped. Can someone please help, my only guesses are all the dirt road, and bumps, me friend (still on learners) said it is her fault because everything she touches breaks because he alternator stuffed up, please help. Quote
mikeys toy[RL] Posted May 22, 2005 Report Posted May 22, 2005 do you guys use e.g.r. valves over there? the vibrations from the road could have loosened a chunk of carbon and it could have gotten jammed in the port. Quote
coln72 Posted May 22, 2005 Report Posted May 22, 2005 The wire hasn't fallen off of the soleniod (spelling) on you carby. The one that stops it from running on. That will stuff up your idle. Quote
blown 5k Posted May 23, 2005 Report Posted May 23, 2005 If the idle solenoid wires fallen off it wont idle at all,might have a bit of dirt in the idle circuit. Quote
Super Jamie Posted May 23, 2005 Report Posted May 23, 2005 your o-ring was probably leaking then, they're sposed to stop the car :thumbsup: Quote
coln72 Posted May 23, 2005 Report Posted May 23, 2005 In my experience, the car will still run without that wire connected but it runs crap and idles crap. Quote
Super Jamie Posted May 24, 2005 Report Posted May 24, 2005 well, matt's fell off when he was living in toowoombah and the car would idle for like 30 seconds then die. i wouldn't know, i've never run one :thumbsup: Quote
KE70_Rolla Posted May 26, 2005 Author Report Posted May 26, 2005 it's sorta of fixed at the moment, got my dad to look at it, he just adjusted the idle screw, now when it is warm it revs at grand, if I give it a rev it goes down, but the my friend who is driving it at the moment only give it the tiniest rev and it stays the same. I'll just get dad to re adjust it again. Quote
20V_KE35 Posted July 7, 2005 Report Posted July 7, 2005 guys, what are the effect if my idle is at 800rpm compare to 1000rpm? other then stuck in traffic fuel comsumtion, what are the effect to the engine performance? hope this is a different question Quote
Xany Posted July 7, 2005 Report Posted July 7, 2005 no effect on engine performance....just fuel consumption.... Quote
demuire Posted July 7, 2005 Report Posted July 7, 2005 Engine idling is basically just to keep the engine running, so you don't need to start it again everytime you want to go. So, generally tune it to the lowest you can get it to and still have the engine running (for best fuel economy). I've set mine on my 4AGE up a bit higher because at low RPM my battery doesn't charge and my oil pressure drops very low. Quote
20V_KE35 Posted July 7, 2005 Report Posted July 7, 2005 I've set mine on my 4AGE up a bit higher because at low RPM my battery doesn't charge and my oil pressure drops very low. what!!! stock k idle at what, i just set it to 800rpm. before was 1000rpm. alamak nanti pressure minyak tak naik, mati aku!!! :P Quote
Redwarf Posted July 7, 2005 Report Posted July 7, 2005 alamak nanti pressure minyak tak naik, mati aku!!! :P Nil comprehendeh. Stock idle is, according to the magic book, 600rpm. I personally think that's a bit low. 7-800 would be fine. Quote
demuire Posted July 7, 2005 Report Posted July 7, 2005 7-800 should be fine. Your oil pressure will come up when you rev it back up, don't worry about that. I just got a bit sick of my oil pressure light coming on everytime I sat at traffic lights and the like, so I raised the idle. Quote
20V_KE35 Posted July 12, 2005 Report Posted July 12, 2005 (edited) OK...i set my idle at 1000rpm. but in the cold start it drop to 600rpm and giving me pain in the ass to start it in the morning. it keep stalling. is it do me any good to equip me 3k with electronic distributor?(it doesnt use contact point) Edited July 12, 2005 by 20V_KE35 Quote
