Or another 2 word solution...
Zip Ties!
Not a bad idea that.
If you have a dodgy head gasket, you will find that as it deteriorates, you'll eventually see a browny capuccino type of foam coming out your radiator cap as the car warms up.
bruce, if you're mechanically able, it's not much to rip the head off, get it skimmed and put in a new HG, and you should be able to get it all fixed for <100 bucks.
And as I'm coming down to Hobart nearly every weekend lately* I more than happy to come round and help you re-assemble.
Would only take us an hour or two if you have everything there ready to go.
*Off-topic but, if you haven't seen I'm a dad already (13 weeks early) so I'm coming down regularly to see my boy. Has your missus popped yet? she was due june/july wasn't she?
That's allowing ample time for K chat, couple of beers, drain a couple of beers, several nut scratches and maybe a "woops we forgot this bit". :bash:
I could probably do a head swap (minus manifolds) in under 28 minutes, but thats something I'd do on Dirt, not somebody elses car. hehehe
If the car never gets to operating temperature, boil the thermostat in a pot of water with a thermometer. Make sure it closes all the way up when cold.
If the thermostat checks out ok consider trying this:
In very cold climates try partially blocking the radiator as an experiment. Maybe get a bit of cardboard and put it in front of the radiator so it say blocks off half of the fins. If this makes an improvement make up a blind/shutter system that can be controlled from inside the car.
I will do that.
Note that i have no fan connected up too the engine.
but I have a thermo fan (used it about once in the maccas drive thru)
ill just buy a new thermostat checking is too much effort haha
Edited by webb
Engines got a cracked piston skirt (rattle), so planning on doing a rebuild; new gaskets, pistons, cam, bit of head work and carbs later on. Looking for a rental house at the moment. Not much around. I'll let you know when I find one.
Pretty soon now, few more weeks.
