Any engine conversion is possible with enough research, time and money!!
Getting a 4efte to bolt up to a K50 IS however impossible. :y:
the hardest part would be trying to get a rwd gear box to bolt up does any one have 4efte engien ? check and see if its close to the k or t series g/box you might have to get an adapter made for it but still sounds like a fun idea i like
T-series g'box with the A-series bellhousing should bolt up fine.
But i don't know if the flywheel will be ok to use cause the motor as far as i know wasn't used in a RWD car.
But it does have the RWD mounts (or at least from what i've seen and could work out). You'll have to relocate a few of the bolt-on bits, brackets and pipes so that you can get to the mounts.
The next problem is that the dizzy is at the back of the head....
