Medicine_Man Posted May 21, 2005 Report Posted May 21, 2005 Stock AW11 MR2 rear water outlet (will not clear the firewall) Quote
Medicine_Man Posted May 21, 2005 Author Report Posted May 21, 2005 4AGZE rear water outlet (Not sure what Car / Year of engine it came off, will clear the firewall, AE82 twincam ones do the same job apparently). Quote
Medicine_Man Posted May 21, 2005 Author Report Posted May 21, 2005 Also note that the 4AGZE outlet has 2 sensors, whereas the AW11 MR2 outlet only has one. The connectors for the sensors are different types too. I'm going to attempt swapping the AW11's Green sensor into the 4AGZE outlet where its green sensor is. By looking at it they appear to be the same size, This way I will have no probelms sticking with my stock AW11 MR2 ECU / AW11 MR2 wiring harness. Quote
demuire Posted May 21, 2005 Report Posted May 21, 2005 AE82 twinky water outlet is flatter. I don't think I have a photo of one though. Quote
Medicine_Man Posted May 22, 2005 Author Report Posted May 22, 2005 OK. Today I confirmed that the green sensors in both the AW11 rear water outlet and the 4AGZE rear water outlet have the same size thread and can be swapped. Left: AW11 4AGE rear water outlet temp sensor (green) Part# 89422-30020 869 Right: 4AGZE rear water outlet temp sensor (green) Part# 89422-20010 10K12 Quote
Medicine_Man Posted May 22, 2005 Author Report Posted May 22, 2005 4AGZE rear water outlet housing (brown sensor) Part# 89462-20030 10K04 Quote
Medicine_Man Posted May 22, 2005 Author Report Posted May 22, 2005 4AGZE rear water outlet housing with AW11 MR2 Green temperature sensor installed. Quote
