ke55 need more camber. sigma LCA is waayyyyyy to much.
what other LCA will bolt straight in and give me a health 2 degrees of camber?
i think i read corona?
thank you in advance
Evan
Corona LCA is exactly the same length as the Corolla one so it will not give you extra camber.
I have been told about a Cressida one that might be longer and may suit, but I don't know anything about it.
Not so for the KE70. I fitted 'rona arms, they are 10mm longer. Are the KE55 arms already longer than the KE70?
just get some camber tops, then you can dial it in to whatever you want..
failing that:
XT130-KE55 - 310mm
MX62 - 365mm
GE Sigma - 330mm
S13 350mm
its only 20mm difference between the sigma an xt.. man up i say :yes:
failing that:
XT130-KE55 - 310mm
MX62 - 365mm
GE Sigma - 330mm
S13 350mm
long story short sigma LCA are they way to go?
Bear in mind, that you need to account not only for length of control arm, but also balljoint pin diameter (or substituting a different balljoint to suit both control arm and appropriate length steering arm) when considering different control arms.
Apparently both length and thickness are important, or so my wife assures me. 8/
Messing with front end geometry is not as simple as you might think.
Also remember when adding camber in the form of longer LCA's, not only will get "hektic" camberz, you will get 20mm more track per side. so if you had rims that sit flush with your guards. they will now poke out up to 20mm more.
just get camber tops, you keep your track, and can tuck the top of the rim inside the guard if you have some decent offset rims 8/
