bmews Posted May 19, 2005 Report Posted May 19, 2005 Firstly, yes I have searched for the subject to no avail. Still having some trouble in the cold mornings. I don't have a manual so could someone tell me what it says about choke/throttle adjustment. IE how much should the choke linkage open the throttle when the choke is applied. Quote
Super Jamie Posted May 19, 2005 Report Posted May 19, 2005 (edited) you'll have to take the carby off to measure the factory spec. pull the choke lever until the flap up top completely closes. the primary throttle plate should be actuated so there is precisely 1.43mm (.056") clearance between the primary throttle plate and the throttle bore this is from yellow book: Edited May 19, 2005 by Super Jamie Quote
bmews Posted May 19, 2005 Author Report Posted May 19, 2005 Many thanks, This place is such a gold mine of information.. Barry Quote
