Old fella Posted May 31, 2009 Report Posted May 31, 2009 I`ve been given a few 3k/4k hotty cams, in real good condition and am looking for info as to their specs. I have two that are marked CE 657, one marked CE 701 and one marked LM 298 S. I`m aware that the CE stands for Camshaft Engineering but that company has now shut down in Brisvegas so no info is to be had from them. The CE701 gets a mention in the how to build a hot K motor section but the others are completely unknown to me. Can someone out there help please. p.s. also scored a real nicely ported 4k head with 3k big port manifold, a set of balanced conrods with new 1st oversize pistons and a balanced crankshaft. A bloke that I know is having a clean up of his farm and was going to sell it all for scrap. Quote
altezzaclub Posted June 1, 2009 Report Posted June 1, 2009 If you've got a spare engine you can put them in and measure their specs on one cylinder. A degree wheel will give you inlet/exhaust opening times and a dial guage will tell you valve lift... You might have something quite surprising in there! Nice score! I'm amazed at what is parked behind the sheds on farms around the Central West here... Quote
Old fella Posted June 1, 2009 Author Report Posted June 1, 2009 If you've got a spare engine you can put them in and measure their specs on one cylinder. A degree wheel will give you inlet/exhaust opening times and a dial guage will tell you valve lift... You might have something quite surprising in there! Nice score! I'm amazed at what is parked behind the sheds on farms around the Central West here... Thanks mate, I`ll give it a try. My mate also has a smith load of KE 20 bits that have been stored for years. He and his sons used to race them in hill climbs and local sprints. I haven`t had a chance yet to go through what is there, but I will as soon as I get the chance. I know that there is a KE 20 roller amongst it all and a heap of interior stuff that was taken out prior to conversion to race cars. Again, thanks. Quote
Doogs Posted June 1, 2009 Report Posted June 1, 2009 Thanks mate, I`ll give it a try. My mate also has a smith load of KE 20 bits that have been stored for years. He and his sons used to race them in hill climbs and local sprints. I haven`t had a chance yet to go through what is there, but I will as soon as I get the chance. I know that there is a KE 20 roller amongst it all and a heap of interior stuff that was taken out prior to conversion to race cars.Again, thanks. It would be good if you could sell whatever you don't need on the forums. can't help you with the cams other than also suggesting you put each in a motor and take readings from there. Quote
Old fella Posted June 1, 2009 Author Report Posted June 1, 2009 It would be good if you could sell whatever you don't need on the forums.can't help you with the cams other than also suggesting you put each in a motor and take readings from there. Thanks mate, as soon as I get a chance to catalogue and photograph what is there, it will be open slather in the sales forum. The 3K boys will go nuts!!! Quote
philbey Posted June 2, 2009 Report Posted June 2, 2009 Just on that note, I did the same thing with my cam, plotted the points of the cam lobe etc against TDC. If I were to do it again, I would actually use my dial gauge measuring off the top of a lifter, rather than straight off the cam lobe itself. You can do it but you need to account for the diameter of the tip of your dial gauge. also, Plot your curve at less than 5 degree increments - I did 5 and it would have been better to do it at 2 deg or similar. Quote
