The_Lab Posted May 22, 2009 Report Posted May 22, 2009 (edited) First things first, I'm unsure if this is the right forum, so modes please feel free to move it where ever appropriate if I've stuffed up. Ok basically I have come across a fairly clean KE70 shell and the plan is to throw in a 4k. Not just any old 4k I'll strip it down to a bare block and be building it myself. My questions are. Can anyone point me in the right direction to find forged pistons, and cam's. I'm sure I can still pick up a gasket kit etc. Also I did a quick search looking for a 4kc build but there doesn't seem to be anything. So any advice you have will be great. (Please try provide a link or atleast a picture.) Thanks guy's I know I'm asking for alot here but I hope you come through :D Edited May 22, 2009 by The_Lab Quote
dopedx Posted May 23, 2009 Report Posted May 23, 2009 This MAY help..... http://www.rollaclub.com/faq/index.php?tit...a_tough_K_motor Quote
The_Lab Posted May 23, 2009 Author Report Posted May 23, 2009 This MAY help..... http://www.rollaclub.com/faq/index.php?tit...a_tough_K_motor i spent more than 3 mins looking and also just found that. just finished reading it :no2: I'm a drifter but no Fujiwara Takumi :D I want a tough little KE to roll around in and make bozo style noise :fuzz: Government says no forced induction ill roll around in an angry ass KE loud as a mutha f@$ker :cool: The hunt is on for a 4k. :cool: Quote
philbey Posted May 23, 2009 Report Posted May 23, 2009 Forget forged pistons. Cams are easy as; choose your grind, send it off, done. 4K's always come up on Ebay. Quote
The_Lab Posted May 23, 2009 Author Report Posted May 23, 2009 (edited) Forget forged pistons. Cams are easy as; choose your grind, send it off, done. 4K's always come up on Ebay. i read that standard ACL's will do the trick :D Edited May 23, 2009 by The_Lab Quote
philbey Posted May 25, 2009 Report Posted May 25, 2009 Yeh, and you're not going to need forged pistons. A set of ACL's should cost about 140 in 20, 40 and 60 thou over. Quote
The_Lab Posted May 26, 2009 Author Report Posted May 26, 2009 Yeh, and you're not going to need forged pistons. A set of ACL's should cost about 140 in 20, 40 and 60 thou over. cheering. Appears this motor build might be cheap :dance: Quote
