what is the diameter of the stock KE30 front spring? I have some springs out of another car and I'd love to use them if the diameter is close enough.
really? 15mm? these springs are from a big V8 dodge and measure 15.9mm thick. the outside dimm is 13.443cm
Edited by vagen
the reason they can run such thicker springs is because they have a larger OD. Spring rates are a relationship between 3 parameters: wire diameter, spring diameter and the number of coils.
