altezzaclub Posted September 4, 2009 Report Posted September 4, 2009 Quote try using some thick ass HYDRALIC OIL (not diff oil/ used engine oil etc etc) But don't expect it to work! You need to look at the viscosity index of the oils, or you will end up with something that thins out too quickly when it heats up. You should also test the viscosity of the oils if you don't have that listed from the manufacturer, as a slight change in viscosity may mean a big change in shock stiffness and you can end up with rigid shocks. I found a hydralic oil designed for machinery in Antartica worked well, but this was over 20years ago & I can't remember the name. It was quite thin but resisted temperature change very well. While I haven't had a rolla strut apart, we used to alter the valving on Datsun 1600 struts for rallying, a simple job involving blocking some holes in the bump and rebound valves, then use a thinnish oil. That worked OK. Slapper you sound like an old bugger, I'm sure you could teach the young guys on here stacks of stuff in some good tech articles... Quote
Redwarf Posted September 4, 2009 Report Posted September 4, 2009 Also make sure that the oil you are using is compatible with the seals in the strut. Some hydruaulic oils will EAT the seals...... Quote
Evan G Posted September 4, 2009 Report Posted September 4, 2009 Redwarf said: Also make sure that the oil you are using is compatible with the seals in the strut. Some hydruaulic oils will EAT the seals...... aka don't use diff oil/ brakefluid/ used engine oil I'm gonna go to super cheap tomorrow and look for thick ass hydralic oil :P Quote
Redwarf Posted September 4, 2009 Report Posted September 4, 2009 No, certain types of hydraulic oil are not compatible. Not just the above. Quote
coln72 Posted September 4, 2009 Report Posted September 4, 2009 If you are going to change oil in your struts, talk to a motorcycle shop that plays with race bikes. They should have some idea of what can be used and what can't. And yes, don't use old engine oil. It ate through the seals in one day :P Quote
Evan G Posted September 4, 2009 Report Posted September 4, 2009 coln72 said: If you are going to change oil in your struts, talk to a motorcycle shop that plays with race bikes. They should have some idea of what can be used and what can't. And yes, don't use old engine oil. It ate through the seals in one day :P hahahhahaha :cool: please add this to my "dodgiest mods youve done to your car" topic Quote
KE55PIG Posted September 29, 2009 Report Posted September 29, 2009 don't no if this has been answered but is there a sway bar that will mouth straight up to the origonal ke55 rear sway bar that is stiffer ? Quote
anastasios Posted September 29, 2009 Report Posted September 29, 2009 maybe give whiteline a call? Quote
coln72 Posted September 29, 2009 Report Posted September 29, 2009 (edited) Quote don't no if this has been answered but is there a sway bar that will mouth straight up to the origonal ke55 rear sway bar that is stiffer ? Why - do you like single spinning to a standstill any time you go near a corner??????? Edited September 29, 2009 by coln72 Quote
KE55PIG Posted October 3, 2009 Report Posted October 3, 2009 i need the car stiff as possible its drift only car Quote
coln72 Posted October 3, 2009 Report Posted October 3, 2009 Just make it solid then - why bother with suspension :) Quote
Evan G Posted August 14, 2010 Report Posted August 14, 2010 (edited) a little thread reserrection, went down to my local pedders store and asked for std height springs for mine, they only had lowered ones witch shares the same part number with N13 nissian pulsars! so if your pov and want a little low, go down your local wreckers and look for the pulsar section! happy rolling Edited September 26, 2010 by Evan G Quote
OMR510 Posted October 14, 2010 Report Posted October 14, 2010 more thread resurrection....... I checked out the Whiteline site for swaybars and the only ones listed for the KE 3X series exclude the wagon. Anyone know why or have any ideas as I really want to improve my cars handling. AFAIK there is no real difference in suspension between the sedans and wagons. Feel free to prove me wrong though as I am a Rolla noob lol Quote
towe001 Posted October 14, 2010 Report Posted October 14, 2010 On 8/14/2010 at 11:04 AM, Evan G said: a little thread reserrection, went down to my local pedders store and asked for std height springs for mine, they only had lowered ones witch shares the same part number with N13 nissian pulsars! so if your pov and want a little low, go down your local wreckers and look for the pulsar section! happy rolling Question - front or back on the N13 ? Quote
