my suspension is as follows:
stock springs professionally cut and rewound (cost = firstborn)
shocks stock wet with oil changed to 50w not under damped by any means.
rear re-stacked leafs main leaf inverted
new vintage KYB competition shocks
again not underdamped
sway bar is stock but with aluminum "D" bushes and poly end bushes.
A couple of quick questions
Do VN wagon rear shockers fit into a ke55 rear?
If i invert the rear leafs with the vn wagon shocks will they bottom out?
Before going for new stock shockers in the front can i add some thicker hydralic oil? (ill be running Eb rears springs in the front) should i worrie about front shocks?
sierra front shockers,
vn wagon shocks,
bmw E30 shocks,
what else bolts right in?
  silverra23 said:
Cutting and grinding is not good for the heat treatment of the spring! This is why its suggested that this is a bad idea.
hackshaw, couple of blades and a 4 pack of redbull :)
Do what you like to your own car, as long as you know the risks. It probably won't fail, but if it does and you end up in a prang and injure someone, your insurance isn't going to want a bar of it and you will be up for the costs. Of course there is the conscience factor too..
But I am an old bloke and like to do things properly. You go for your life :)
Not to mention the legal factor too. If you kill someone you CAN be charged with manslaughter for running cut springs.
  nichy said:
whats alll this about bmw e30 shocks fitting in a ke?
rear I'm guessing
ive read somewhere you can get bmw e30 rears, drill the eye out and there u have a realllllyyyyy firm rear suspension
but no1 has done this or can comfirm it on rollaclub :)
  nichy said:
i have accsess to e30 rears :wink:
are they short stroke?
i not sure all i know there "bmw E30 rears" all older beemers have a realllyyy firm ride and weight 1300kgs and a ke55 weighs 900kg so yeaa
and no bmw e30/e21 came out with drums on the rear
try put em in and let me know the results
Evan
Edited by Evan G
  • Downvote 1
sigma LCA are they the pressed in or bolted in?
GE sigma (twin headlights?)
how much camber do they add?
Evan
