Just got my leaf springs reset for the KE55.. asked for a 2" drop and one leaf add in to make 5 a pack.
Got them home today, put them in and its only dropped by 1" its still 4wd style :P And they did cost a pretty penny to get done :hmm:
Now will they "set" into place over a few days? will i get my extra 1" i paid for? Or should i be ringing them up and complain?
Edited by Falken_KE30
I'd be giving them a call and asking what the go is. From what i know the leaves would set that extra 1" in a few years or so, not in a few days.
Did you move the car before tightening it all up?? It should settle after a single run around the block. Also if they rest them, THEN put the extra leaf in it might hold it higher. They should know thier shit though.
yeap, i took it for a drive, the double checked all the nuts.
I got a Added leaf put in so you would think they would compensate the extra stiffness?
Ryan, got slogged $240 for them to pull down, blast them clean add a Leaf, reset and paint Black.
they'll usually pull them down, reset them, then set another (extra) leaf to suit.
you do know i probably could have got you brand newies + post for probably not much more than what they slugged ya :P
ouch.
I flipped mine which lowered it about 2" then i got 2" lowering blocks......
yeah i wanted to pass on the lowering blocks, hence why i thought i could get them reset low.
Ohwell, it don't look so high now the front is dropped 2" :P
yea same, but had no choice.
with all my suspension work, its the best handling car I have ever owned.
Are you kidding me? A car with flipped leaves is the best handling car you've ever owned? My KE30 had flipped leaves and it was terrible.
Have you been driving magnas for most of your life?
Mine handles ok,
but i go shit tyres on rear, and it really needs new front shocks. one of mine is leaking :P
But yeah its alot better to drive it hard though corners, but bumps suck.
Considering selling it soon anyway... Make way for a Bigger car :hmm:
have sway bars, and sierra shocks.
you would be surprised.
