1.6hydro Posted April 28, 2009 Report Posted April 28, 2009 hi I have a 7 rib block but it has no oil return pipe, The other 7rib I have has it and also oil squirters. Can I still use a smallport head on the block with no oil return pipe?? Quote
the witzl Posted May 6, 2009 Report Posted May 6, 2009 you can... but you'll have to block the oil return line from the head. Its probably there for a reason, so i *personally* would try to keep it functional. Quote
