kangaroosa Posted April 25, 2009 Report Posted April 25, 2009 i just put trx rims on mine and there 15x7 i put are 5mm spacer front and back didnt need to roll my back graud and my back is dropped 2and are half inchs i will put pics up on monday.. TRX rims are 15" x 6" with about 30P or 32P......unless yours have been modified. But being an alloy rim, i can't see that happening I now run them on mine as its the only wheel that will get me under the front maximum track allowance. Quote
tbo92 Posted April 25, 2009 Author Report Posted April 25, 2009 Hi Guys, thanks heaps for all your replies.. It would appear 3 say +25 - and 2 say +12. from my understanding of things, the standard wheel is 5" wide, and is +27 offset, so if i am putting 7" wide, would i be correct to say that i WILL need the +12 offset to bring the wheel away from the struts? Thanks again! Quote
Falken_KE30 Posted April 25, 2009 Report Posted April 25, 2009 +12 yes... depends on the look you like, do you want to the rim to tuck inside the guard, or so you want the rim dead even with the guard? +4 will give it even with guards, maybe slightly more :) Quote
tbo92 Posted April 26, 2009 Author Report Posted April 26, 2009 +12 yes... depends on the look you like, do you want to the rim to tuck inside the guard, or so you want the rim dead even with the guard? +4 will give it even with guards, maybe slightly more :) Hey thanks matey - yeah i would like it in the guard, as i live up in the mountains (WOO mountain runs ;)) and i don't want the side wall rubbing all the time! Thanks heaps for your imput mate! Quote
raffs rolla Posted April 28, 2009 Report Posted April 28, 2009 i just put are 5mm spacer at the front and the back fit good and did have 2 do anything esle to them :P Quote
