kiahn Posted April 20, 2009 Report Posted April 20, 2009 i have been sold a t-18 cross member and told it would work in my 4k-4a conversion, i was also told that the t series gearbox would fit, as i have tried the gearbox and it didn't work so I'm starting to wonder if the Xmember will work too. Quote
SKA80R Posted April 20, 2009 Report Posted April 20, 2009 (edited) i have been sold a t-18 cross member and told it would work in my 4k-4a conversion,i was also told that the t series gearbox would fit, as i have tried the gearbox and it didn't work so I'm starting to wonder if the Xmember will work too. do yo have any pics of the cross member? I am looking to buy a T18 gear box x member? Edited April 20, 2009 by SKA80R Quote
fusion Posted April 20, 2009 Report Posted April 20, 2009 The T50 won't work unless you use a 4A bellhousing. That is ofcourse with me assuming you mean you have a T50 with a T series bellhousing. Quote
LukeAE71 Posted April 21, 2009 Report Posted April 21, 2009 i have been sold a t-18 cross member and told it would work in my 4k-4a conversion,i was also told that the t series gearbox would fit, as i have tried the gearbox and it didn't work so I'm starting to wonder if the Xmember will work too. You have bought a T series crossmember which will only fit a T series motor. You need an A series crossmember which you can get from an AE71 either automatic or manual. It all makes sense that you have to have stuff from the same series. Quote
adam-__- Posted April 21, 2009 Report Posted April 21, 2009 Engine cross member you're asking about right? If you're wanting a 4AGE in your KE70, you will need an A series cross member unless the T18/T series one you've got at the moment has modified mounts. If you were talking about gearbox cross member, all T50 gearbox cross members should be the same. Bell housing is the main difference when it comes to fitting on another motor. Quote
kiahn Posted April 21, 2009 Author Report Posted April 21, 2009 (edited) yeh i didnt think the t18 Xmember would fit, bit pissed off now. thanks all Edited April 21, 2009 by kiahn Quote
LittleRedSpirit Posted April 21, 2009 Report Posted April 21, 2009 yeh i didnt think the t18 Xmember would fit, bit pissed off now. thanks all Id have thought the lack of steering rack mounts on it might have been the first thing youd notice to tell you it wouldnt work. Bummer. Get the A series gear and go again. Quote
